solo
Hi all,
Just happily unpacked and connected the N66U to replace my WNDR3700v2. Since last week I updated my cable to 50 Mbps, I figured a new router was in order. Ky ISP provided a Cisco DPC3008 cable modem. The N66U is running on 3.0.0.4.246.
I have an xbox, tivo, and a wd live tv hard-wired to the router, and one Compaq 2510p laptop, one Sony vaio SVZ131190X, two Samsung Galaxy S phones, one MacMini, one kindle, and one wd live tv devices that connect via wifi (normally 2.5 GHz)
The issue:
I have a 50 MBit line with my ISP (RCN). When testing via wireless (I can use either speedtest.net or RCN's own speedtest website) most I get is about 7 Mbit on any of my wifi devices BUT my phones, which max out at 22 Mbps. Any downloads I start on my wifi connected laptops / macmini / Kindle are not going faster that 50-100 KB/s. I see a lot of timeouts, and dropped packets. Pinging IPs rarely works. BUT If I hardwire my laptops / macmini to the WNDR, all speed tests max out at 55 Mbps, and all downloads are super fast. Also, the 5GHz range is basically 5 ft. If I go behind the wall, it is gone.
What I did to troubleshoot:
The issue is the same on both 2.4 / 5 Ghz frequencies. I tried changing the Tx Power adjustment to 100, 150 and 200 but it only got worse with the increase. I power cycled the router / modem / all devices multiple times. I tried flushing DNS caches, IP release / renew etc. I tried doing a factory reset on the router, including changing the SSID and password. Still, the issue over wifi persists.
Could anyone here make a suggestion on what might be causing the issue? I think I got a defective unit.
Thanks!
The issue:
Thanks!
