AX 11000
SoulRaver
Ok so, I've typed in google many times in regard to my current issue and have only gotten threads in regard to other routers or information stating that it's the OS's fault. However, my Router's lan ports including the 2.4GBPS port is capped at 100MBPS. I've checked my WAN status and it says 1gbps. I went through so much trouble of uninstalling and reinstalling my network drivers on my PC thinking the drivers were at fault, but in reality I feel the router is just bad. I've done factory resets several times with different firmwares and still don't know whats wrong. I've also hard wired straight from my actual modem which is an Arris modem and my network adapter registers it as a 1GBPS connection with a speed test done and getting over 400-480 down. It all keeps going back to the router. So what are solutions with this issue? I have most settings disabled due to reading other threads. Despite changing out and testing different Cat cables of each kind, the results are the same.
Edit: The modem I'm using particularly is the Arris SB8200
ISP: Spectrum
