Ax-16000 vs Ax-11000 Pro
128bit
it's that time of year and our 'puters have been after santa to make them happier. frankly, we're fairly set with our current meshed network, but i'm curious if the ax16000 can use that 6g band as a backhaul when meshed? if so, that would likely mean i'd need a pair of 6g capable devices, but they're priced better these days and considering my clients, we'll be happy as wifi 6 "patients" for the foreseeable. a pair of ax-11000 pro routers is not out of the question if the second 5g band is selectable as a "clean" backhaul pipe. just curious.
if the above can't be accomplished, is the ax-11000 pro a significant enough upgrade for replacing the ax88u pro which has been stellar as a main, or even its meshed beast, the gt-ax6000? the ax88u pro surprisingly provided better coverage, so it got promoted to a main.
still, there are some weak spots. so, while the waves are a-flowing nicely, just keeping an eye out for a better wifi 6 option.
. . . any experiences or advice would be appreciated.
