I've learned the hard way, more than once, to ask first ... I have a history of breaking things ... Thanks!Why not just download 388.2_2 manually and install it manually using the Manual firmware update upload link?
Sometimes the update notice isn't triggered when one uses the Checks button. Just manually update instead.
Per my post edit above, make sure to select the correct Check button, the second (lower) one. It should indicate either an update is available, or that you have the latest version installed.I've learned the hard way, more than once, to ask first ... I have a history of breaking things ... Thanks!
OK, cool, I'll remember that ...Per my post edit above, make sure to select the correct Check button, the second (lower) one. It should indicate either an update is available, or that you have the latest version installed.
Welcome To SNBForums
