AX router with minimum power requeriments
tiomiguel
I have a DGS-1100-05PDV2 Gigabit Ethernet Switch, powered from another NETGEAR POE switch
DGS-1100-05PDV2 Gigabit Ethernet Switch only can supply TWO CLASS2 POE at the same time (7 W each maximum). In one port I hace a FOSCAM CAM and in the other port I have RT-AX55 in AP mode. RT-AX55 only boot with 2,4 Ghz in power save TX power and 5 Ghz disabled. I would like boot with 5 Ghz too, so, is there any ASUS device with lower power requeriments? Perhaps RT-AX52, RT-AX53U? any advice?
The power consumption of RT-AX55 will perhaps increase with 1W or less with both radios enabled on full power. You are in Europe, 2.4GHz max Tx power is 20dBm or 100mW, 5GHz non-DFS is 23dBm or 200mW. Don't use Power Save setting, it cuts the radios down to single stream greatly impacting the performance. Use Balance instead if you don't need range. I believe you're good in any configuration. Hello from Andalusia.
With FILOGIC 830 devices, like my TUF-AX6000 gateway and two RT-AX59U in AP mode, TX power save DOES NOT cut to single stream (proved)
Thank you for testing this on your routers. Seems like the behavior on MediaTek hardware based devices is different. I still believe you are fine with any setting. The difference in total power consumption is minimal.
I use Power Saving on 2.4GHz and Fair on 5GHz for a long time on RT-AX86S - the radios connect to 2 streams.
2.4GHz
5GHz
OK but Rt-AX57 is broadcom chipset and power save mode does not cut radios. 2 streams are presnet in power save mode. I know difference in total power is minimal but I have a dlink POE switch DGS-1100-05PDV2 that have two class 2 ports -max 7W each port- booting router reaches 7W and shutdown. I have ordered TRENDNET TPE-P521ES that allow me distribute 18W between two ports: 12 + 6 (for a cam)
What is exactly the use case of this setup? If one wire reaches the router's location another can reach it too.
I hope the new switch doesn't have a similar problem :)
The new switch arrived and has ths esame problem. You can not distribute power as you want. Only class 2 + class 2 max allowed
I have the RT-BE58 Go in active service so could measure its power consumption during normal operation if you want? Even if its consumption is below 7W you may still experience problems due to in-rush current when the router is first powered on as this could be instantaneously more than your PoE can supply. You would have to try it and see.
