AX11000 Pro IoT Network Issue
billybruce
I was using a GT-AX11000 router for my apartment setup but recently moved into a house and wasn’t getting a strong signal throughout. I decided to upgrade to the AX11000PRO after finding a deal online and using the older router as a node in a mesh network. The signal is much better now and I was able to setup an IoT network with the better firmware on the pro model.
However, I’m noticing that any IoT devices connected to my node are not listed as being connected to the IoT network when I check my router settings. The IP address associated with them has a 52 which is what I chose for the VLAN. Is this just a quirk of the firmware or is there something else I should be doing?
