spruce-jackal
My internet is 1gbps fiber and my new AX3000 is getting ~900/900 UL/DL on ethernet. With Wi-Fi from about a foot away I'm getting 800-900mbps UL, but weirdly only 400-500mbps DL (similar results on multiple devices). I've disabled 2.4ghz, set the 5ghz wireless mode to "AX Only" since all my devices support AX and set channel bandwidth to 160mhz (not 20/40/80/160) - speeds haven't moved up or down after these changes.
What router settings should I be tweaking to get my Wi-Fi DL speeds up closer to where my UL speeds are?
