AX3000 - port forward not working
fishface
AX3000 - port forward working fine with Asus fw from Jan 2022, I think it was this 3.0.0.4.386.47029.
I had a port forward set-up for my cameras (BlueIris), all worked fine, I could access the cameras from outside the LAN with no issue, over several years, I have also used the same configuration on previous Asus routers, RT-AC68U etc.
A few days ago I updated the router to Merlin RT-AX58U_386.5_0.
I configured the port forward just as I have always done, but it refuses to work, I cannot connect to Blue Iris externally, the only way I can get it to work is to add the Blue Iris server IP to the WAN > DMZ section "IP Address of Exposed Station" and then it works.
Is this the way it now works? Or is there something else going on here?
