Hi Gurus,
I am trying to connect my AX53u as a media bridge to my main router AX86s.
The logs keep showing this and the wifi connection won't establish. I tried hard reset and all the stuff and reconfigure, it just won't connect.
ay 5 13:08:32 kernel: [ 223.414051] Set_Channel_Proc: Channel(161), Cert(0), Quick(0)
May 5 13:08:32 kernel: [ 223.420110] rtmp_set_channel(caller:Set_Channel_Proc+0x170/0x250), Channel(161), quick_ch_change:0.
May 5 13:08:32 kernel: [ 223.429356] APStop() Invalid oper(1)
May 5 13:08:32 kernel: [ 223.432963] APStartUp() Invalid oper(1)
May 5 13:08:32 kernel: [ 223.446859] I/F(apcli1) Set_ApCli_Enable_Proc:
enable = 1)
May 5 13:08:36 kernel: [ 227.374390] cntl_connect_request,Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
May 5 13:08:37 kernel: [ 228.464269] ApSiteSurvey_by_wdev::Failed!!!Scan is running, please try again after scan done!
May 5 13:08:38 kernel: [ 229.374368] cntl_connect_request,Return since CNTL not IDLE,CNTL(1),SYNC(0),AUTH(0),ASSOC(0)
May 5 13:08:40 kernel: [ 231.374358] cntl_connect_request,Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
May 5 13:08:41 kernel: [ 232.504197] I/F(apcli1) Set_ApCli_Enable_Proc:
enable = 0)
May 5 13:08:50 kernel: [ 241.693183] Set_Channel_Proc: Channel(161), Cert(0), Quick(0)
May 5 13:08:50 kernel: [ 241.699112] rtmp_set_channel(caller:Set_Channel_Proc+0x170/0x250), Channel(161), quick_ch_change:0.
May 5 13:08:50 kernel: [ 241.708319] APStop() Invalid oper(1)
May 5 13:08:50 kernel: [ 241.711895] APStartUp() Invalid oper(1)
May 5 13:08:50 kernel: [ 241.730609] I/F(apcli1) Set_ApCli_Enable_Proc:
enable = 1)
Anyone know why and how can I get this fix ?
