Hello, I have a Asus RT-AX86u with merlin 388.2_2 with skynet and diversion, both of which are up to date. I keep getting the same blocked incoming connections to a MAC address on my network but I can't find the associated device. I'm wondering if it's something I even need to worry about or if I can just ignore it. I also have a AC68u that I've been trying to use in aimesh mode (wired) but a couple minutes after setting it up, it goes offline and I have to reset the router to set it up again. I got around it by setting it up in bridge mode for now. The log is pasted below. Any direction would be helpful.
May 14 11:47:34 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=79.124.62.86 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=63948 PROTO=TCP SPT=45488 DPT=5590 SEQ=147458734 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:47:45 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=95.214.55.85 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=54321 PROTO=TCP SPT=38328 DPT=9091 SEQ=250372660 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:47:52 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=89.248.163.7 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=36387 PROTO=TCP SPT=59708 DPT=35763 SEQ=602202916 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:48:04 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=91.240.118.77 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=51135 PROTO=TCP SPT=56985 DPT=10015 SEQ=4046325268 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:48:07 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=107.170.243.26 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=249 ID=54321 PROTO=TCP SPT=42125 DPT=9443 SEQ=1227841959 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:48:14 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=193.163.125.76 DST=173.75.230.180 LEN=44 TOS=0x08 PREC=0x20 TTL=247 ID=38469 PROTO=TCP SPT=57053 DPT=10011 SEQ=1550862898 ACK=0 WINDOW=14600 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
May 14 11:48:19 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=79.124.60.202 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=61977 PROTO=TCP SPT=49864 DPT=1781 SEQ=57872984 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:48:22 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=162.142.125.138 DST=173.75.230.180 LEN=73 TOS=0x00 PREC=0x00 TTL=46 ID=8986 PROTO=UDP SPT=56403 DPT=53 LEN=53 MARK=0x8000000
May 14 11:48:36 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=89.248.163.7 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=49812 PROTO=TCP SPT=59708 DPT=35355 SEQ=603434555 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:48:38 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=176.111.174.81 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=24822 PROTO=TCP SPT=43908 DPT=8025 SEQ=375953691 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:48:52 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=176.111.174.86 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=64378 PROTO=TCP SPT=44065 DPT=8412 SEQ=304102674 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:49:01 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=89.248.163.75 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=58788 PROTO=TCP SPT=45968 DPT=29870 SEQ=604927934 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:49:41 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=89.248.163.166 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=63195 PROTO=TCP SPT=58627 DPT=32863 SEQ=1999605808 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:49:56 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=162.216.149.100 DST=173.75.230.180 LEN=44 TOS=0x00 PREC=0x60 TTL=252 ID=42238 PROTO=TCP SPT=57266 DPT=59127 SEQ=3487409341 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
May 14 11:50:06 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=87.246.7.206 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=54321 PROTO=TCP SPT=39068 DPT=8443 SEQ=1853811749 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:50:11 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=79.124.62.82 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=27233 PROTO=TCP SPT=45487 DPT=38810 SEQ=3164216143 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:50:17 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=162.216.150.154 DST=173.75.230.180 LEN=44 TOS=0x00 PREC=0x60 TTL=252 ID=42001 PROTO=TCP SPT=54392 DPT=45139 SEQ=2979918582 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 OPT (020405B4) MARK=0x8000000
May 14 11:50:21 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=91.191.209.198 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=50154 PROTO=TCP SPT=54505 DPT=13330 SEQ=550506828 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:50:31 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=194.26.29.86 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=27302 PROTO=TCP SPT=57197 DPT=52001 SEQ=3833874227 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:50:39 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=176.111.174.84 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=52122 PROTO=TCP SPT=43991 DPT=8176 SEQ=2343187166 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:50:43 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=89.248.163.64 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=59703 PROTO=TCP SPT=44289 DPT=7790 SEQ=2265059821 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
May 14 11:51:04 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=d4:5d:64:34:64:38:5c:45:27:d6:59:c7:08:00 SRC=89.248.163.57 DST=173.75.230.180 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=870 PROTO=TCP SPT=58524 DPT=29583 SEQ=1549899357 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
