AX86U - how to get Wireguard and Pihole working together
camaro322hp
Hello all. Question regarding Wireguard/Pihole.
I have a Pihole set up as my DNS server on my network. I set its IP as my DNS Server 1 on the LAN - DHCP Server tab. I am not advertising the router's IP in addition. It's working great for devices on my network.
I also have a Wireguard VPN Server configured on my AX86U so I can access my home network when I'm away. It's also working great.
However, I noticed that when I'm away and VPN'ed to my home, I don't have any ads blocked. It appears that the VPN connection is not using the router's DNS server.
Here is my Wireguard setup. Not sure what I should change here, if anything.
I noticed on the VPN peer config, there is a line that says:
DNS = 10.6.0.1
(but that does not appear to be configurable). My network is based on the 192.168.1.xxx subnet. Not sure where 10. is coming from, but I am a networking novice.
Anyone know what I need to do to get these working together? I am running ASUSWRT latest (22525)
Use Diversion on the router. Uses the same block lists as Pi-Hole.
I'm willing to try that, but wouldn't I end up with the same issue? I feel like the issue is with Wireguard not using the router's DNS server, so using a different DNS server on the router wouldn't change anything.
VPN Servers use whatever is set in WAN for DNS servers. I was playing with 388_22525 recently, OpenVPN and Instant Guard - the same for both. You have to find a way to push DNS servers to your VPN Server clients, but I don't know how it works for WireGuard. Possible with OpenVPN Server.
In your Wireguard exported config file you should be able to change the line "DNS = " to the address of the Pi-Hole
[Interface]
PrivateKey =
Address = 10.6.0.2/32
DNS = 192.168.1.5
Then import the file into the Wireguard client.
[Interface]
PrivateKey =
DNS = 192.168.1.5
Thanks, I'll give that a try.
[Interface]
PrivateKey =
DNS = 192.168.1.5
That worked, thank you for the suggestion @bbunge!
