Just testing my new AX86u Pro connected to ISP (Rogers) cable modem using the 2.5 Gb WAN port with a CAT6a cable. I get about 1800 Mb/s on the router's speed test (firmware 388.24199). From my desktop on the 1 Gb wired connection I get about 850-890 Gb/s using SpeedTest app.
In this configuration, I was curious if the regular 1 Gb WAN port could be used as a LAN port - sure enough it works. So with WAN connected via 2.5 Gb port, you have 5 1 Gb LAN ports.
