ax86u - show my wired connect as wireless (5G) in network map list
kamanwu
Is there any way to fix this? How the router know it's wired connection or wireless connection? Thanks.
Welcome to the world of wonky Network Map. May fix itself after a day when the DHCP cycles. Then again, maybe not.
The issue has been there more than 1 month. Also, this is one of my server. I use static IP, not dhcp.
I've posted this just now in a different topic (RT-AC68U - Issues and problem with upgrading firmware):
Yesterday I upgraded manually my AC68u, which I'm using at work.
I also did a full factory reset, because my NVRAM was full for some reason I don't know.
What I noticed was that while reconfiguring the wireless networks, I had a lot of troubles when switching between de 2.4GHz and 5GHz networks. I kept seeing the 5GHz network even if I selected the 2.4GHz. This resulted that the wireless passwords got mixed up every time I hit the apply-button. I also have MAC-Filtering activated, here the MAC addresses got mixed up between the two networks also.
The networks need to be hidden, work policy, but with the latest firmware I neither could connect to the wireless networks "No network found".
I think the 386.13 firmware has some bugs, or perhaps versions before but I just noticed this now.
I reverted to firmware 386.12.6, but didn't solve the problem. I'm now back at 386.12 and have everything working, but it's an old firmware and would like a newer one...of course.
I hope an update with fixed will come out soonest.
Nothing to fix. This is a stable release.
Your update/upgrade method(s) needs to be explained and examined.
