AX89X Different SFP+ Behavior on Reboot vs Power Off then Power ON
dhendodong
When router is being Rebooted the SFP+ module isn't powered on it needs to be manually removed and reinserted for it to be powered on again and this is a big problem because i use the SFP+ as WAN and every time i reboot the router i lose WAN and i need to reinsert the SFP+ MODULE each time I reboot the router. I hope it will be fixed that if you reboot the SFP+ module also reboot or will be powered/rebooted too.
However when the router is physically Powered Off then Powered On the issue is not present the SFP+ module is powered on automatically.
