pacoinconn1
I have a couple of questions about manual IP assignments. I assign manual IP addresses for all of our devices (extenders, laptops, phones, wi-fi thermostats, etc.). Almost all use the "regular" networks (2.4 and 5). The wi-fi thermostats and vacuum cleaner use only the Guest networks (2.5 and 5).
I have a few questions:
1. Even though I've. listed the IP Pool Sarting and Ending Addresses from 192.YYY.X.1 to 192.YYY.1.XXX, devices that use the guest network (the vacuum and various visitors'. devices) are assigned 192.YYY.101.YYY or 192.YYY.ZZ. Aren't these addresses outside the iP Pool?
2. This bevhavior doesn't apply to 2 of the 3 wi-fi thermostats. All three use the guest network, all three are manually assigned IPs within the IP Pool and yet one wi-fi thermostat consistently shows up on an IP address outside the range, despite being assigned an IP address like the other two.
3. In the Network Map list, what does is the difference between a "Manual" and "Static" Client IP address?
Appreciate the help for this amateur consumer trying to learn and manage my home network.
