BE92U Running new beta 2 firmware, dnsmasq keeps crashing my internet says unable to obtain ip address and no internet connection
Wizzy_TBG
I disable jffs and configs it works again
I was trying to use this
cache-size=10000
dns-forward-max=500
min-cache-ttl=3600
neg-ttl=60
no-negcache
bogus-priv
domain-needed
fast-dns-retry
stop-dns-rebind
rebind-localhost-ok
log-async=25
edns-packet-max=1232
Am i just being stupid or have i set up wrong?
My DNS is 8.8.8.8 and 1.1.1.1 ipv4 and ipv6
BT Full Fibre 900mb
Many of those options are already added by the firmware. How were you adding them? Duplicating an option may cause dnsmasq to fail to start.
Both can be true. ;)
Yes most likely!
Using Putty SSH
Enter command
nano /jffs/configs/dnsmasq.conf.add
Entered
cache-size=10000
dns-forward-max=500
min-cache-ttl=3600
neg-ttl=60
no-negcache
bogus-priv
domain-needed
fast-dns-retry
stop-dns-rebind
rebind-localhost-ok
log-async=25
edns-pack
et-max=1232
Then Crtl + X
Y
Then save
Then reboot dnsmasq
These parameters are managed by the firmware.
bogus-priv
cache-size
dns-forward-max
domain-needed
edns-packet-max
log-async
no-negcache
stop-dns-rebind
Look at /etc/dnsmasq.conf before appending things in dnsmasq.conf.add.
Is there any way to edit the values currently used? Or are they set also completely separate but is adaptive qos still broken on BE Wifi 7 Routers mine does nothing so i just disabled it in the end
You can write a postconf script to modify the generated conf file before dnsmasq starts. That way you can replace an existing line, delete an existing line, or append a new entry.
I was running DoT DNS servers but ipv6 was blocking but that was fixed in most recent update i read online those changes often help but i tried it and it didnt work so was jist seeing if i had it wrong and if its worth actually trying to set up or not! But if you think its not i'll give it a miss
