Beefy (preferably Asus) router for wired usage
wakil78793
Hello.
I'm searching a router (preferably Asus with Merlin) with a beefy CPU and specs.
Wireless will be turned off and used as a wired router (1000/100 Mbps IPS, VPN, Zoom, Teams, downloading etc.).
Which one would be the best?
Thanks!
If you want high routing performance without wifi, then I recommend going down the homebrew route, with a small fanless PC and something like pfsense. For the same price you will get much better routing performance.
Hello.
Thanks!
Along the lines of a homebrew mentioned above, here is one example, not the cheapest, just to get an idea. You could ad AP's later if you wanted to. Honestly, probably the lowest budget model running Pfsense could handle your needs. Wireguard, Suricata, Pfblocker all easy add ons to Pfsense, really stable, documentation is top notch. I would say it does require some basic understanding of networking environment but if you don't do a lot of frigging around it just works.
