Solved Beginners firewall question.
Henk-J
I wanted to install NGINX om my RT-AX82U, and used these instructions:
My firewall /jffs/scripts/firewall-start script is as follows:
#!/bin/sh
iptables -I INPUT -p tcp --dport 80 -j ACCEPT
iptables -I INPUT -p tcp --dport 443 -j ACCEPT
I must be overlooking something, as the NGINX works ok inport 80 from the LAN side but when I want to access using the WAN side (using hotspot on my phone or antoher internt connection, , unfortunatly it does not work.
So how to make port 80/443 directly accessible from the WAN side? (I know I could try port forwarding)
I would start by confirming that nginx is actually listening on the WAN interface.
netstat -nlp | grep -E ":80 |:443 "
Yes it works, it even shows my costum index.html
Started with 80 only:
admin@RT-AX82U-4BD8:/tmp/home/root# netstat -nlp | grep -E ":80"
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 2121/nginx: master
tcp 0 0 :::80 :::* LISTEN 2121/nginx: master
Check that your rules are properly applied, with "iptables -L INPUT -vn".
Make sure your public IP isn't CGNAT, and that you aren't double NATed. Also, some ISPs might block well known service ports such as 80,443,25, etc...
Solved: I had portforwarding configured. Overlooked it
Can you expand on that a bit for the ignorant? You don't need port forwarding in this case, and it interfered? Is this NGINX server upstream of the firewall?
I had port forwarding configured a very looong time ago, forwarded port 80/443, to an internal ip, and completly forgot all about it.
