best setting for PS4 with the AC87U?
Cazzoi
Hello.
does anyone have a PS4 and know what the best Settings is for the AC87U is there something i can change in the ASUS dashboard or the QOS.
thanks for the help and reply :)
I have a PS4, and a couple of Xbox Ones. All are working well. I am running the firmware listed in my signature with the settings listed in the following post:
http://www.snbforums.com/threads/dd-wrt-for-rt-ac87r.22421/page-11#post-172621
Once you flash a new firmware, it is good practice to reset the router. There are several ways to do this, but the way I do it is to....Telnet into the router and run: mtd-erase2 nvram, then run: reboot. Allow the router to reboot completely until the startup wizard appears, then power cycle the router, and then input all of your settings manually.
Good luck.
Good luck.
If I have an XBox1 and 360, my XB1 is wired and 360 is wireless, and my 360 tells me I don't have an open NAT, but XB1 doesn't complain, how do I ensure I have the best NAT settings for my router? It's just using the most recent firmware from ASUS. Is there a way to optimize the NAT settings for the XB1 so that I get the best online XBLive gaming speeds? Should I consider a non-ASUS firmware? This is the 87U I have by the way.
