Beta 372
DrSuSE
Somehow struggling to find my copy of the beta version of the 372 release, but it was performing better for me.
Anyone able to share a copy?
Thanks in advance.
For what it's worth, I found a copy and have been running it for 3 days without any of the issues I've had with 372 release and 374.
If anyone is interested I'll post it tomorrow.
I've been running the 32 beta and its quite stable. I haven't had issues with it. I have an issue though, when I transfer files from computer to computer i get only about 12 megabytes per second can this router go more than 12? I'm running on ethernet category 5 is that a problem? Do I need to change to category 7 cables to run full gbps speed?
You need a minimum of Cat5e cabling.
Thank you for the advice. Yes I was thinking that I needed new ones. Man I can't believe its been like 10 years since I got a new router. LOL. I haven't even bought new cables for the new router. What a bummer need new ones. I should be good to go right? What kind of speed am I suppose to be getting like 100 megs per second? or if its on ethernet?
