network issue
Even a dirty port or poorly installed jack, or a million other things, can cause problems. Interference on the line (run next to a fluorescent light for example, a nick in the cable,...) or anything that causes retries can eventually overload the network, and therefore overload a port and potentially cause a switch to reset.
It will likely come down to the process of elimination. If possible start with as simple a test scenario as possible (direct wire the 2 PCs together for example) and then add devices/cables/switches 1 by 1 and keep retrying.
I just saw this thread. This suggestion is probably way off base, but if one of the PC's is a Dell you may have some 3rd party bloatware getting in the way. If you have SmartByte installed on some Dell computers and are sending (or receiving?) a large stream of large packets Smartbyte may briefly disable the network interface. I know this happens with WiFi; I'm not sure about Ethernet.
depends on what is shorting / breaking in the connection.
The key is to see what change the issue follows.
If it follows a cable, then change it. If it follows a specific PC, add a new NIC and test.
If a new switch powers off or reboots, could be cable or power or switch. You can also get a "storm" of packets from failing hardware as retransmits overwhelm the LAN.
When you said the lights went off on the switch, was that the activity/sync led or the power led or both ?
I saw the activity lights go off on the old switch at every failure. Haven't observed that happening on the new switch, I wasn't watching the one time that a copy failed (so far) on the new switch.
I can't see the problem being other devices on the network - just a couple laptops using wifi, ipads and iphones using wifi, a couple wired media streamers, a couple wired network drives, some cams using wifi - all small consumer products.
So I guess it's pointing to either a failing NIC or bad drivers. I don't know enough to replace either, so I'll have to take it in to a shop and have them do it.
I suspect PC2 because I also saw failure once in a while when I copied files from a network drive to PC2. I'll have to start there.
Thanks guys.
Both are asus, and no bloatware - I removed everything when I got them.
Thanks.
Thanks guys.
In the OP, you said
Another quirk is, when this error happens, it will also abort any download I happen to be doing at the time, so somehow the error is affecting some other network communication.
Is this on any machine or just the one you were copying from or copying to ?
Is this repeatable on the same machine only ?
Thanks guys.
If you do take it into a shop, have them clean the connection points on any card plugged in and also on all the memory sticks installed. Reseating cables too.
You might try using a USB ethernet network adapter and see if you get the same result or not for each PC.
Yes, repeated a few times before I got wise. It happens on the from-machine. I only download on the from-machine and then copy files to the to-machine. So it seems when the old switch reset, it also affected the download.
I'm going to get a new NIC on PC2 (the to-machine) in January, and ask them to update whatever driver it needs. I have a hunch that's probably the culprit, because several times in the past, the failure occasionally happened when I copied a file, using PC2, from a network drive directly to PC2, so PC1 was not involved.
Thanks again.
I'm not saying it is your issue, but it is VERY easy for anything on your network (wired in this case) to introduce interference and therefor flood the network with bad traffic and retries. That is how ethernet works. I've seen a bad light switch take down dozens of servers or a bad wall jack take out a whole segment.
A network monitor may be able to rule this in or out.
Just trying to give you ideas you may not have thought of.
i was assuming an onboard NIC with the motherboard.
Just to close the loop...
You were correct... the original NIC was an onboard one... I got a new card and so far no problems.
I have a feeling it's actually a bit faster and steadier than the old one... on the old one I could see some speed fluctuations, but not now. I'm guessing onboard stuff is less perfect than a dedicated card.
Thanks again.
