[Beta] RT-AC66U Firmware version 9.0.0.4.380.2695
rtcomputersinc
[Beta release]
Security Related
- Modified the access rights of account mode and share mode to asusware.platform path when lighttpd server is enabled. (Très Acton at BAE Systems Applied Intelligence)
- Modified the access rights to specific port of UPnP server. (Thanks to Acton)
- Updated lighttpd server version to 1.4.39 (Thanks to Tommi)
- Restriced access from wan method to enhance security. (Thanks for David)
- Changed SSH and Telnet default access interface.
New Features
- Supported auto dynamic port changing of UPnP server when ports conflict.
- Supported more ASUS Router App new features
Bug fixed
- Fixed the GUI issue for reboot scheduler
- Fixed httpd/ Telnetd/ SSH restart issue after LAN address change
Download: Click here
It appears that this FW and previous one breaks the usb rollover for usb modem. I have a Pantech UML290 usb aircard that works fine with FW 9459. It will not work with 9533 or 380.2695 so looks like problem introduced on 9533. If I go from a working 9459 upgrade to 9533 prior to reset it stopped working. If I downgrade back to 9459 prior to reset it works fine. I skipped directly to 380.2695 from 9459 not working. I have done resets and it still wont work. So looks to be a bug.
Source has loads of blobs missing emf.o,igs.o
fixed them then its a new pile of errors
atleast there's a source drop i suppose
but would make life so much easier if they actually checked it
Driver version
Jan 25 2016 17:35:24 6.30.163.2002 (r382208)
