I had thought of using the Ubiquiti ER-X but have never personally used it. Was wondering if it is capable of supporting vlans and 802.1Q since there are two vlans being utilized on dd-wrt in this particular instance.
Injector included as per Amazon:
https://www.amazon.ca/dp/B0781YXFBT/?tag=smallncom-20
You probably manage yourself your network, @PcGuy. What @Trip is suggesting is the way to go. I wasn't comfortable to offer such solution. You may need time or pro services to set it up. I just mentioned SMB above to see what the reaction is going to be.
Another suggestion, quick and easy:
- use the router for WAN to LAN traffic only, should be good to about 100Mbps
- if you need VLANs, get a managed switch, create VLANs there
- if you don't need VLANs, get a dumb switch for $20
- connect LAN devices and AP to the switch, Gigabit WLAN to LAN traffic
Welcome To SNBForums
