speedyrules
hi guys,
need your help!
first, i have read the ultimate guide, which is pinned on the VPN forum.. and i also found/read 3 other threads which i worked through .. but i am being to stupid to get this running
my setup
router 1 - ASUS RT-AC87U
running latest original firmware
lan setting ip address router: 192.168.81.1
subnet mask: 255.255.255.0
openvpn - server
router 2 - ASUS RT-AC68U
lan setting ip address router: 192.168.0.1
openvpn - client
client name "openvpn"
the client connects.. and all devices behind the client can access all other servers in the router 1 lan
BUT: i cannot access from a computer in router lan 1 to any server behind the router 2 lan
for example i cannot access from my 192.168.81.158 to 192.168.0.4.
what the heck am i doing wrong?
maybe here some settings
routing table at client
Destination Gateway Genmask Flags Metric Ref Use Type Iface
10.8.0.5 * 255.255.255.255 UH 0 0 0 tun15
10.8.0.1 10.8.0.5 255.255.255.255 UGH 0 0 0 tun15
xxx.xxx.42.1 * 255.255.255.255 UH 0 0 0 WAN0 eth0
10.8.1.2 * 255.255.255.255 UH 0 0 0 tun21
192.168.81.0 10.8.0.5 255.255.255.0 UG 0 0 0 tun15
10.8.1.0 10.8.1.2 255.255.255.0 UG 0 0 0 tun21
192.168.0.0 * 255.255.255.0 U 0 0 0 LAN br0
xxx.xxx.42.0 * 255.255.254.0 U 0 0 0 WAN0 eth0
default xxx.xxx.42.1 0.0.0.0 UG 0 0 0 WAN0 eth0
routing table at server
10.8.0.2 * 255.255.255.255 UH 0 0 0 tun21
xxx.xxx.2.1 * 255.255.255.255 UH 0 0 0 WAN0 vlan2
169.254.39.0 * 255.255.255.0 U 0 0 0 LAN br0
192.168.81.0 * 255.255.255.0 U 0 0 0 LAN br0
xxx.xxx.2.0 * 255.255.255.0 U 0 0 0 WAN0 vlan2
10.8.0.0 10.8.0.2 255.255.255.0 UG 0 0 0 tun21
192.168.0.0 10.8.0.2 255.255.255.0 UG 0 0 0 tun21
default xxx.xxx.2.1 0.0.0.0 UG 0 0 0 WAN0 vlan2
openvpn config in openvpn - server
thanks for the help.. this situation is driving me nuts :O
need your help!
my setup
openvpn - server
openvpn - client
