Block Client Quirk - RT-AX86U
ChitlinNoodleSoup
Firmware version 388.1
If I click on the client bubble from the network map screen, then click on a client and attempt to block internet access, it doesn't appear the setting takes. I can hit apply, then go right back to the same client, and it's off again. If I go to parental controls, I see the device listed there as blocked.
Is this expected behavior, or should I be able to see which devices are currently blocked via the client list? Or is my router just being an *******?
