Bonded DSL on RT-AC1900P
hifiwifi
My ISP has a deal on bonded DSL, which would effectively double my current speeds up and down. Would I be able to continue to use my RT-AC1900P as my router, presumably in dual WAN mode? I am currently running my DSL modem in bridge mode with it, and it works very well.
Thank you for any advice. I am running 380.68_4 if that matters.
With bonded DSL you still only get 1 WAN interface with 1 IP address. You’ll have a modem with 2 DSL interfaces and 1 WAN interface your your router.
This makes sense. I misunderstood how bonded DSL works. It's not load balancing with dual WAN at all, then. Thank you.
Yes it’s often confused with load balanced lines. Might be worth confirming with your ISP it really is bonded and not balanced!
