Bricked RT-AX82U Red case light and white power light only
rockyutvols
Hi
I bought a used RT-AX82U from eBay that was listed "working" When I turned it on, it will only light up the white power light and the red case light (the ones that change color). I have tried recovery mode and it does not work. It will only do what I described over and over and with each reboot. The eBay seller refunded my money so I am not out anything. I am just curious if there is anything I can do to tinker with this and try and fix it. I have used a serial TTL on Linksys routers before but never on Asus. Does anyone have a picture of the pinout I would be looking for or a how to guide or any advice on where to start in general? Thanks in advance.
