I have a Netgear FVS318G firewall router, which I am in the process of setting up. Testing it in my home environment, I connected it to a BT Home Hub 3, which is connected to the BT Infinity service; I get 37mb/sec on this connection.
The FVS318G can deliver two separate LAN connections, using the main LAN ports for the first, and a DMZ port for the second. The purpose of this arrangement in my project is to offer internet access to two separate groups of users, while denying them access to each other's LAN. In my home test, this worked perfectly.
I then took the router to the target environment, and set it up in exactly the same way. However, although the LAN connection and the DMZ connection functioned correctly, the internet connection was not delivered to either, as the FVS318G did not appear to register the WAN; the principal difference is that in this case, the internet connection is coming from a Netgear DG834v5 router, with a connection speed of around 1mb/sec.
The WAN port on the FVS318G appeared to pick up the signal from the DG834v5, but occasionally seemed to drop it. The WAN monitoring section consistently showed the connection as DOWN.
Can anyone shed light on this, as I've run out of ideas.
