bug in 3006.105.0 newly configured gt-axe16000 dns not working on router in ap mode/static ip
lgkahn
i have issue on my gt axe-16000 i just got to replace the 11000
the upstairs gt-axe16000 runing older 3004 build works fine.. the new one dns does not work on the router when static ip is assigned,
it is running latest release build.. see attachement and below.
ASUSWRT-Merlin GT-AXE16000 3006.102.5_0 Sun Aug 3 16:23:49 UTC 2025
admin1@GT-AXE16000downstairs:/tmp/home/root# ping www.ebay.com
ping: bad address 'www.ebay.com'
admin1@GT-AXE16000downstairs:/tmp/home/root# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=114 time=21.012 ms
64 bytes from 8.8.8.8: seq=1 ttl=114 time=17.257 ms
^C
--- 8.8.8.8 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 17.257/19.134/21.012 ms
admin1@GT-AXE16000downstairs:/tmp/home/root# nslookup www.ebay.com 8.8.8.8
Server: 8.8.8.8
Address 1: 8.8.8.8 dns.google
Address 1: 23.194.190.185 a23-194-190-185.deploy.static.akamaitechnologies.com
Address 2: 23.194.190.154 a23-194-190-154.deploy.static.akamaitechnologies.com
i believe the issue is the /etc/resolv.conf is blank and not being populated correctly even though (see below) dns servers are configured)
thats definatley the issue:
when i configured the resolv.con as on the other router it works fine.
it should look like this
any ideas why its not being populated on boot
nameserver 75.75.76.76
nameserver 8.8.8.8
nameserver 192.168.11.1
working now after reboot after i manually configured the resolv.conf.. i guess it is persistant accross boots?
strange setting up the lan static config doesnt populate it..
I guess that is the bug..
