Some DNS not resolving with router IP but resolved on explicit DNS IP
lala_cai
My setup is as follows
- Rt-ac86u with 384.12
- Initiated reset with Initialize.
- configured only stock WAN, wifi, DDNS and swap memory.
- no DNSFilter, no AiProtection
Encounter some very strange problem. I start noticing some sites some images not loading accordingly.
I did some check and notice the following when doing a nslookup from my pc
c:\>nslookup
Default Server:  router.asus.com
Address:  192.168.1.1
> sg-test-11.slatic.net
Non-authoritative answer:
> server 8.8.8.8
Default Server:  dns.google
Address:  8.8.8.8
Server:  dns.google
Address:  8.8.8.8
Address:  23.201.156.188
Aliases:  sg-test-11.slatic.net
          content.lazada.com
          slatic.net.edgekey.net
If I were to ssh to the router and do a lookup, it can resolve
admin@RT-AC86U:/tmp/home/root# nslookup sg-test-11.slatic.net
Server:    8.8.8.8
Address 1: 8.8.8.8 dns.google
Address 1: 23.201.156.188 a23-201-156-188.deploy.static.akamaitechnologies.com
Possible to advise any other places which i should be looking at for this issue?
You appear to be located in Malaysia. If I use a Malaysian proxy I can see that 8.8.8.8 returns the addresses whereas 1.1.1.1 does not. The 1.1.1.1 server works fine when accessed from here in the UK.
So this is an issue with the 1.1.1.1 DNS server when accessed from Malaysia.
Hi @ColinTaylor ,
Yes, that was the problem. Thanks again. I changed it to use all google DNS now instead.
I'm not sure why the 1.1.1.1 is not resolving accordingly
