Bug! Saving System Log - syslog.txt is blank [384.4_b3]
Flipmode11
G'day!
Updated with the latest 384 firmware when it came through on my device.
Click Save on System Log page and the saved syslog.txt is simply empty / blank. Worked previously.
c:\users\account\downloads\syslog.txt is saved as 0 bytes when log is 15 pages.
Worked on Asus AC86u f/w and Merlin 380 f/w for AC66u. Forget previous Merlin 384 f/w used.
Thanks mate
Model RT-AC86U
Firmware Version 384.4_beta3
Firmware Build Sat Mar 10 18:31:47 UTC 2018 merlin@644942d
Temperatures 2.4 GHz: 52°C - 5 GHz: 56°C - CPU: 67°C
CPU Load Average 3.18, 3.66, 3.71
CPU Model Cortex B53 ARMv8 (Cores: 2)
CPU Frequency 1800 MHz
Memory 430.11 MB Used - 170.46 MB Free
Cache 21.91 MB | Buffers 0.00 MB | Swap 0.00 / 0.00 MB
NVRAM usage 64833 / 131072 bytes
JFFS 5.63 / 48.00 MB
HW acceleration Runner: Disabled - Flow Cache: Enabled
Connections 478 / 300000 - 69 active
Req! Please add VPN connection info on Network Status (home) page. Pretty please?
Plus display available ROM storage space in use, total and available. ;)
Download works on my side with firmware 384.4 (first release) like a charm:
C:\Users\Josi\Downloads>dir syslog.txt
29/03/2018  22:17           334.733 syslog.txt
               1 File(s)        334.733 bytes
Did you clear browser cache after firmware update? Maybe it can prevents the download if not... :rolleyes:
But you are on Merlin 384.4_beta1 and I am on Merlin F/W 384.4_beta3.
So perhaps Beta 1 was not affected.
