build error with new asuswrt 382 source code for RT-AC3100
bsdsource
I was attempting to build the new source code based on the 382 code that Asus just released for the RT-AC3100 and I'm getting this error I can't seem to get passed:
linux/linux-2.6.36 -f - ARCH=arm modules
make[4]: Entering directory '/root/asuswrt/release/src-rt-7.14.114.x/src/linux/linux-2.6.36'
  CHK     include/linux/version.h
  CHK     include/generated/utsrelease.h
make[5]: 'include/generated/mach-types.h' is up to date.
  CALL    scripts/checksyscalls.sh
  CHK     include/generated/compile.h
  Kernel: arch/arm/boot/Image is ready
  SHIPPED arch/arm/boot/compressed/mpcore_cache.S
  AS      arch/arm/boot/compressed/mpcore_cache.o
  SHIPPED arch/arm/boot/compressed/lib1funcs.S
  AS      arch/arm/boot/compressed/lib1funcs.o
  LD      arch/arm/boot/compressed/vmlinux
  OBJCOPY arch/arm/boot/zImage
  Kernel: arch/arm/boot/zImage is ready
make[4]: Leaving directory '/root/asuswrt/release/src-rt-7.14.114.x/src/linux/linux-2.6.36'
  LD [M]  drivers/net/ctf/ctf.o
  LD [M]  drivers/net/dhd/dhd.o
  LD [M]  drivers/net/dhd24/dhd24.o
  LD [M]  drivers/net/dpsta/dpsta.o
  LD [M]  drivers/net/et/et.o
  Building modules, stage 2.
  MODPOST 109 modules
WARNING: could not find drivers/net/ctf/../../../../../../src/router/ctf_arm/linux/.ctf.o.cmd for drivers/net/ctf/../../../../../../src/router/ctf_arm/linux/ctf.o
WARNING: could not find drivers/net/dhd/../../../../../../dhd/src/dhd/linux/.dhd.o.cmd for drivers/net/dhd/../../../../../../dhd/src/dhd/linux/dhd.o
WARNING: could not find drivers/net/dhd24/../../../../../../dhd24/src/dhd/linux/.dhd24.o.cmd for drivers/net/dhd24/../../../../../../dhd24/src/dhd/linux/dhd24.o
WARNING: could not find drivers/net/dpsta/../../../../../../../src/router/dpsta/linux/.dpsta.o.cmd for drivers/net/dpsta/../../../../../../../src/router/dpsta/linux/dpsta.o
WARNING: could not find drivers/net/emf/../../../../../../src/router/emf_arm_7114/.emf.o.cmd for drivers/net/emf/../../../../../../src/router/emf_arm_7114/emf.o
WARNING: could not find drivers/net/et/../../../../../../src/et/linux/.et.o.cmd for drivers/net/et/../../../../../../src/et/linux/et.o
WARNING: could not find drivers/net/igs/../../../../../../src/router/emf_arm_7114/.igs.o.cmd for drivers/net/igs/../../../../../../src/router/emf_arm_7114/igs.o
ERROR: "robo_permit_fwd_rsv_mcast" [drivers/net/et/et.ko] undefined!
ERROR: "robo_bhdr_register" [drivers/net/et/et.ko] undefined!
ERROR: "robo_bhdr_unregister" [drivers/net/et/et.ko] undefined!
ERROR: "dump_previous_oops" [drivers/net/et/et.ko] undefined!
ERROR: "robo_get_linksts" [drivers/net/et/et.ko] undefined!
ERROR: "robo_update_agg_group" [drivers/net/et/et.ko] undefined!
ERROR: "robo_get_portsts" [drivers/net/et/et.ko] undefined!
/root/asuswrt/release/src-rt-7.14.114.x/src/linux/linux-2.6.36/scripts/Makefile.modpost:91: recipe for target '__modpost' failed
make[5]: *** [__modpost] Error 1
/tmp/Gm4LjI4M:1134: recipe for target 'modules' failed
make[4]: *** [modules] Error 2
Makefile:1423: recipe for target 'kernel' failed
make[3]: *** [kernel] Error 2
make[3]: Leaving directory '/root/asuswrt/release/src/router'
Makefile:382: recipe for target 'all' failed
make[2]: *** [all] Error 2
make[2]: Leaving directory '/root/asuswrt/release/src-rt-7.14.114.x/src'
Makefile:3689: recipe for target 'bin' failed
make[1]: *** [bin] Error 2
make[1]: Leaving directory '/root/asuswrt/release/src-rt-7.14.114.x/src'
Makefile:3831: recipe for target 'RT-AC3100' failed
make: *** [RT-AC3100] Error 2
Any ideas?
So I'm still unable to get passed this et.ko undefined error. I can bypass the error by deleting everything in the makefile located at ~/asuswrt/release/src-rt-7.14.114.x/src/linux/linux-2.6.36/drivers/net/et/Makefile to allow the build process to continue. There has been some other proprietary binary issues I had to address in with the build process and have managed to fix those. I'm still stuck on this. If RMerlin or someone else can help out I would appreciate it.
Updating my findings since my original resolution wasn't the correct solution. In src-rt/target.mak I had LACP (Link Aggregation Control Protocol) set to n (no). The closed source ET driver requires LACP. Setting this to y (yes) resolved the build error.
