Bypass on RT-AX88U
RCF
Hello i have RT-AX88U (firmw. 384.18_0 ) with a vpn client configuration, all traffic goes throw that vpn but cant get plex to work, read alot os posts to bypass it.. and its all the same i get my vpn ip on plex server.
As anyone bypass it correctly ? Any lights to help with this problem ?
I may have misunderstood myself, but in the other post i was trying to forward a door through vpn. Here let all traffic through the wan to the plex.
Your post is still confusing. If you want all traffic to and from the Plex server to go via the WAN you need to create a policy rule for the Plex server.
If on the other hand you want the Plex server to use the VPN but still be accessible via the WAN you need to use selective port routing (see example 2).
