RT-AX88U Pro Hard Crashing every couple of days
Modem logs have been checked, it's not the modem. That connection is solid. The problem is the router. A reboot of the router without rebooting the modem results in a working network; when the router crashes it stops working for everything, including intra-network traffic.
Well, spoke too soon. Router crashed again last night some time around 2:10am. So, a little over 2 days. This time I have logs from before and during the crash, will be looking at them to see if I can determine what happened.
did you add the accessories back to the router that you had removed earlier? If so, is it possible that they're causing excessive power demand on your router? perhaps you might add a powered USB hub to the mix to see what happens?
At 4 days of uptime with zero issues. Haven't had the time to swap to Merlin yet.
Just got the RMA info for the RT AX-88U Pro, will be getting that out in the mail on Monday or Tuesday.
