Cake and WAN packet overhead (VDSL2 PPPoE PTM UK)
gameinn
Hello everyone
I'm trying to figure out what the ideal wan packet overhead number for a VDSL2 PPPoE PTM (with vlan tagging) connection would be. It's very popular in the UK for FTTC by ISP such as BT (which I have).
Cake seems good enough right now (A+ in bufferbloat) but I would still like to understand the proper values. When you select VDSL2 PPPoE PTM from the drop down, you get these numbers:
To view this content we will need your consent to set third party cookies.
For more detailed information, see our cookies page.
Now after looking at this: https://man7.org/linux/man-pages/man8/tc-cake.8.html
It seems like 30 would be correct. However, since my ISP has vlan tagging I need to look at ether-vlan and add 4 so in total 34. I was still not sure on the "mode" section. In the drop down box it has 3 options: Normal, ATM, PTM
It's likely that Normal = noatm. ATM and PTM are the compensations applied to bandwidth. I did think if I should even use the PTM flag because of this post: viewtopic.php?p=885000#p885628
It should just be better to do the 64/65 calculation (0.984) on bandwidth. Apparently this isn't as CPU intensive or something?
So my questions are:
1: Should I actually be setting 34 on wan packet overhead based on my connection?
2: Should I set the PTM flag or take care of it myself in bandwidth number (0.984)?
Thank you
Bumping an old one and sorry I'm no help. Did you manage to figure out the best settings?
I'm in the exact same predicament 😅 tia
