Can add subversion-server to the usb preset application?
Sorry, I do not understand what you are saying.
What model router do you have?
What firmware version are you using?
RT-AC66U 1
RT-AC86U 1
RT-AC88U 1
RT-AX88U 1
waiting for update
Asuswrt-Merlin​
Most applications under the Servers Center are for sharing files across your network. Subversion, on the other hand, is a version control system and totally unrelated to those under the Servers Center and if I understand you correctly, you want subversion-server to be added there which is highly unlikely.
RT-AC66U 1
RT-AC86U 1
RT-AC88U 1
RT-AX88U 1
waiting for update
Asuswrt-Merlin​
You do not have Asuswrt-Merlin installed on your routers.
1. Install Asuswrt-Merlin
2. Install Entware via SSH
3 Install subversion-server
admin@RT-AX86U:/# opkg info subversion-server
Package: subversion-server
Version: 1.14.1-1
Depends: libc, libssp, librt, libpthread, subversion-libs
Status: unknown ok not-installed
Section: net
Architecture: aarch64-3.10
Filename: subversion-server_1.14.1-1_aarch64-3.10.ipk
Description: Subversion is a free/open-source version control system. That is,
 Subversion manages files and directories, and the changes made to them,
 over time. This allows you to recover older versions of your data, or
 examine the history of how your data changed. In this regard, many
 people think of a version control system as a sort of time machine.
 This package contains the Subversion server.
thanks
I want to put subversion-server in USB Application so that I don't need SSH installation
Its a pretty narrow use case - I doubt Asus (or RMerlin) would add it.
As others have recommended, Entware is likely your only option.
