Can Guest Network Pro (guest network #1) use a DNS server which is located in the main LAN?
Rici
Since I am not sure about the internal routing mechanisms of the Guest Network Pro towards the main LAN: Can my Guest Network clients use a pi-hole located in the main LAN?
My router is RT-AX86U Pro running Merlin FW 3006.102.6 .
Thank you!
