Can I add to the list of supported DDNS providers?
ags
I'm using DNSExit. It is free and supports primary domains. It's not included "out of the box" in the supported list.
Can I add DNSExit myself? If so, does it require ssh (and do I need to hack to expose ssh or is it already supported)?
I did some research and while I'm quite new to Asus products, it seems that there is a common API/module used to take the user settings from the router GUI and construct the proper URL to send to update the DDNS providers (inadyn). Is that just used by DD-WRT?
Asuswrt supports DNS-o-Matic, which in turn supports a very wide range of other DDNS services. See if DNS-o-Matic supports DNSExit, if it does then you can use it to update DNSExit with your WAN IP.
Yes, I thought of that (DNS-o-matic). If necessary that is my fall-back strategy. I'd prefer to not have to have a relay with multiple accounts (and points of failure) if possible. This seems like it should be so easy to accomplish.
Asuswrt uses ez-ipupdate to handle its DDNS updates. DD-WRT uses a different client AFAIK (inadyn probably, been a while since I looked).
