Can I use wildcards in dnsmasq?
Claghorn
I'd like to be able to prevent all windows updates inside my local network, and since everyone is pointing at my merlin based router, that seems like a great place to block lookups of all the names mentioned in https://technet.microsoft.com/en-us/library/bb693717.aspx, but they use wildcards for the names, so I'd need to block using some sort of wildcard mechanism as well. Is this possible with the dnsmasq on merlin?
No, this is not possible in Dnsmasq.
Well not through the GUI. It might be possible with a custom script/config:
http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html
See the --address and --server options (I can't paste the text here because cloudflare block me).
You got me. Using it on all routers of course...
Create /jffs/configs/dnsmasq.conf.add and add whatever you need, one per line, works both for http and https:
address=/windowsupdate.microsoft.com/0.0.0.0
address=/update.microsoft.com/0.0.0.0
Make sure the file has UNIX line ending.
Then restart dnsmasq:
service restart_dnsmasq
Then ping it, it should resolve to 0.0.0.0 or whatever IP you set it.
Just keep in mind - security updates
WannaCry was fixed, and a push rolled out - most folks that got bit by that one, they were blocking WindowsUpdate on those machines.
I don't want to prevent updates forever, I just want to make sure they only happen when I'm ready for them. The last time I was doing my taxes, I went out to lunch and came back to spinning circles telling me not to touch the machine. Aaugh!
I think I remember reading about being able to attach scripts to custom buttons in the GUI, so if I get this to work, perhaps I can add a couple of buttons for enable/disable windows updates :-).
