Can only get to AICloud home page
dakotacody
I just flashed to the latest firmware and now when I visit my routers address I only have the options for the AICloud. How do I access the main configuration page now that AICloud is enabled? I have searched all over and haven't seen any posts addressing this. Any help is appreciated. Also trying to visit any of the links in my history results in a page with only
451 -
on it.
Wow. Thanks for the super quick reply. Unfortunately, that doesn't work for me. Prior to the upgrade of the firmware I had disabled management to only be on port 443. Also I had changed the network to match the address space that was used on my previous router.
Visiting http://172.16.31.1 does not answer and visits to https://172.16.31.1 or using port 8443 give me the AICloud menu.
telnet 172.16.31.1 80
telnet: can't connect to remote host (172.16.31.1): Connection refused
Can (should) I just reflash it?
I can telnet into the router no problems ( prefer SSH so really considering flashing one of your custom firmwares )
That's your issue then. You disabled the port 80 interface, and since you changed the https interface to use port 443, it conflicts with AiCloud. You will have to either re-enable access on port 80, or change https accessfrom port 443 interface to a different port (that's why Asus defaults it to 8443). To do the latter, run these commands over telnet:
nvram set https_lanport=8443
nvram commit
reboot
Your https webui will be back on port 8443 after the reboot.
never turned telnet on
I'm in the same boat as dakotacody. Except I never turned on telnet. Got any other tricks? Short of having to reset the whole thing and set it all up all over again? :(
If you have no telnet, no ssh, no http and no https access, then you can't do anything but reset to factory defaults. Sorry.
H 443 AiCloud vulnerable? ASUS AC Routers & Adapters (Wi-Fi 5) 19
