Can you help with an issue. Log attached
SMW
I've been using Padavan's firmware for a while and have the same issue with every version. I drop my internet connection for a few mins every few days.
I show to be connected via wireless however during the episode I can't log into the router (using 192.168.1.1), can't load webpages. It lasts 2-6 mins then all of sudden everything works fine. This happens on all devices at the same time. (computers, phones, tablets...etc)
If I use ASUS's firmware then it works fine however I need the 2nd SSID and Padavan has better range.
below is a log: Mar 23 20:24 started one of these episodes.
Jan 1 00:00:05 syslogd started: BusyBox v1.21.1
Jan 1 00:00:06 RT-N56U: bootloader version: RT-N56U-01-00-00-06
Jan 1 00:00:06 RT-N56U: firmware version: 3.4.3.7-075
Jan 1 00:00:06 kernel: klogd started: BusyBox v1.21.1 (2014-01-14 04:11:28 KRAT)
Jan 1 00:00:06 kernel: Linux version 3.4.76 (padavan@hms) (gcc version 4.4.7 (GCC) ) #2 Tue Jan 14 04:16:24 KRAT 2014
Jan 1 00:00:06 kernel: The CPU/SYS frequency set to 500/166 MHz
Jan 1 00:00:06 kernel: CPU revision is: 0001974c (MIPS 74Kc)
Jan 1 00:00:06 kernel: Determined physical RAM map:
Jan 1 00:00:06 kernel: memory: 08000000 @ 00000000 (usable)
Jan 1 00:00:06 kernel: Zone PFN ranges:
Jan 1 00:00:06 kernel: Normal 0x00000000 -> 0x00008000
Jan 1 00:00:06 kernel: Movable zone start PFN for each node
Jan 1 00:00:06 kernel: Early memory PFN ranges
Jan 1 00:00:06 kernel: 0: 0x00000000 -> 0x00008000
Jan 1 00:00:06 kernel: On node 0 totalpages: 32768
Jan 1 00:00:06 kernel: free_area_init_node: node 0, pgdat 8035c1d0, node_mem_map 81000000
Jan 1 00:00:06 kernel: Normal zone: 256 pages used for memmap
Jan 1 00:00:06 kernel: Normal zone: 0 pages reserved
Jan 1 00:00:06 kernel: Normal zone: 32512 pages, LIFO batch:7
Jan 1 00:00:06 kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan 1 00:00:06 kernel: pcpu-alloc: [0] 0
Jan 1 00:00:06 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Jan 1 00:00:06 kernel: Kernel command line: console=ttyS0,57600n8 root=/dev/mtdblock4 rootfstype=squashfs
Jan 1 00:00:06 kernel: PID hash table entries: 512 (order: -1, 2048 bytes)
Jan 1 00:00:06 kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:06 kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:06 kernel: Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 00:00:06 kernel: Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
Jan 1 00:00:06 kernel: Writing ErrCtl register=00000000
Jan 1 00:00:06 kernel: Readback ErrCtl register=00000000
Jan 1 00:00:06 kernel: Memory: 126060k/131072k available (2890k kernel code, 5012k reserved, 551k data, 188k init, 0k highmem)
Jan 1 00:00:06 kernel: NR_IRQS:40
Jan 1 00:00:06 kernel: console [ttyS0] enabled
Jan 1 00:00:06 kernel: Calibrating delay loop... 249.34 BogoMIPS (lpj=498688)
Jan 1 00:00:06 kernel: pid_max: default: 32768 minimum: 301
Jan 1 00:00:06 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:06 kernel: NET: Registered protocol family 16
Jan 1 00:00:06 kernel: bio: create slab <bio-0> at 0
Jan 1 00:00:06 kernel: SCSI subsystem initialized
Jan 1 00:00:06 kernel: usbcore: registered new interface driver usbfs
Jan 1 00:00:06 kernel: usbcore: registered new interface driver hub
Jan 1 00:00:06 kernel: usbcore: registered new device driver usb
Jan 1 00:00:06 kernel: PCI host bridge to bus 0000:00
Jan 1 00:00:06 kernel: pci_bus 0000:00: root bus resource [mem 0x20000000-0x2fffffff]
Jan 1 00:00:06 kernel: pci_bus 0000:00: root bus resource [io 0x10160000-0x1016ffff]
Jan 1 00:00:06 kernel: pci 0000:00:00.0: [1814:0802] type 01 class 0x060400
Jan 1 00:00:06 kernel: pci 0000:00:00.0: reg 14: [mem 0x00000000-0x0000ffff]
Jan 1 00:00:06 kernel: pci 0000:00:00.0: supports D1
Jan 1 00:00:06 kernel: pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Jan 1 00:00:06 kernel: pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
Jan 1 00:00:06 kernel: pci 0000:01:00.0: [1814:3091] type 00 class 0x028000
Jan 1 00:00:06 kernel: pci 0000:01:00.0: reg 10: [mem 0x00000000-0x0000ffff]
Jan 1 00:00:06 kernel: pci 0000:01:00.0: PME# supported from D0 D3hot
Jan 1 00:00:06 kernel: pci 0000:00:00.0: BAR 8: assigned [mem 0x20000000-0x200fffff]
Jan 1 00:00:06 kernel: pci 0000:00:00.0: BAR 1: assigned [mem 0x20100000-0x2010ffff]
Jan 1 00:00:06 kernel: pci 0000:01:00.0: BAR 0: assigned [mem 0x20000000-0x2000ffff]
Jan 1 00:00:06 kernel: pci 0000:00:00.0: PCI bridge to [bus 01-01]
Jan 1 00:00:06 kernel: pci 0000:00:00.0: bridge window [mem 0x20000000-0x200fffff]
Jan 1 00:00:06 kernel: Switching to clocksource MIPS
Jan 1 00:00:06 kernel: NET: Registered protocol family 2
Jan 1 00:00:06 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:06 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 00:00:06 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:06 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Jan 1 00:00:06 kernel: TCP: reno registered
Jan 1 00:00:06 kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:06 kernel: UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Jan 1 00:00:06 kernel: PCI: CLS 32 bytes, default 32
Jan 1 00:00:06 kernel: RT3xxx EHCI/OHCI init.
Jan 1 00:00:06 kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 00:00:06 kernel: msgmni has been set to 246
Jan 1 00:00:06 kernel: alg: No test for stdrng (krng)
Jan 1 00:00:06 kernel: io scheduler noop registered (default)
Jan 1 00:00:06 kernel: pcieport 0000:00:00.0: device [1814:0802] has invalid IRQ; check vendor BIOS
Jan 1 00:00:06 kernel: Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Jan 1 00:00:06 kernel: serial8250: ttyS0 at MMIO 0x10000c00 (irq = 12) is a 16550A
Jan 1 00:00:06 kernel: Ralink GPIO driver initialized. Number of GPIO: 96, GPIO mode: 0000185D
Jan 1 00:00:06 kernel: brd: module loaded
Jan 1 00:00:06 kernel: loop: module loaded
Jan 1 00:00:06 kernel: ralink flash device: 0x1000000 at 0x1c000000
Jan 1 00:00:06 kernel: Ralink SoC physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x0000c2 Chip ID 0x0022cb
Jan 1 00:00:06 kernel: Ralink SoC physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
Jan 1 00:00:06 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 1 00:00:06 kernel: Amd/Fujitsu Extended Query version 1.1.
Jan 1 00:00:06 kernel: number of CFI chips: 1
Jan 1 00:00:06 kernel: Creating 7 MTD partitions on "Ralink SoC physically mapped flash":
Jan 1 00:00:06 kernel: 0x000000000000-0x000000030000 : "Bootloader"
Jan 1 00:00:06 kernel: 0x000000030000-0x000000040000 : "Config"
Jan 1 00:00:06 kernel: 0x000000040000-0x000000050000 : "Factory"
Jan 1 00:00:06 kernel: 0x000000050000-0x000000182ff0 : "Kernel"
Jan 1 00:00:06 kernel: 0x000000182ff0-0x0000007f0000 : "RootFS"
Jan 1 00:00:06 kernel: 0x0000007f0000-0x000000800000 : "Storage"
Jan 1 00:00:06 kernel: 0x000000050000-0x000000800000 : "Firmware_Stub"
Jan 1 00:00:06 kernel: tun: Universal TUN/TAP device driver, 1.6
Jan 1 00:00:06 kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Jan 1 00:00:06 kernel: PPP generic driver version 2.4.2
Jan 1 00:00:06 kernel: PPP MPPE Compression module registered
Jan 1 00:00:06 kernel: NET: Registered protocol family 24
Jan 1 00:00:06 kernel: PPTP driver version 0.8.5
Jan 1 00:00:06 kernel: Ralink APSoC Ethernet Driver v3.0.7. Rx/Tx Ring: 256/256. Max packet size: 1536.
Jan 1 00:00:06 kernel: rtl8367 - hw bridge: W|LLLL
Jan 1 00:00:06 kernel: Realtek RTL8367 GigaPHY Switch Driver v2.1.
Jan 1 00:00:06 kernel: usbcore: registered new interface driver libusual
Jan 1 00:00:06 kernel: nf_conntrack version 0.5.0 (16384 buckets, 32768 max)
Jan 1 00:00:06 kernel: xt_time: kernel timezone is -0000
Jan 1 00:00:06 kernel: gre: GRE over IPv4 demultiplexor driver
Jan 1 00:00:06 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:06 kernel: TCP: cubic registered
Jan 1 00:00:06 kernel: NET: Registered protocol family 10
Jan 1 00:00:06 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:06 kernel: IPv6 over IPv4 tunneling driver
Jan 1 00:00:06 kernel: NET: Registered protocol family 17
Jan 1 00:00:06 kernel: Bridge firewalling registered
Jan 1 00:00:06 kernel: L2TP core driver, V2.0
Jan 1 00:00:06 kernel: PPPoL2TP kernel driver, V2.0
Jan 1 00:00:06 kernel: 8021q: 802.1Q VLAN Support v1.8
Jan 1 00:00:06 kernel: ASUS NVRAM, v0.07. Available space: 61440. Integrity: OK
Jan 1 00:00:06 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
Jan 1 00:00:06 kernel: Freeing unused kernel memory: 188k freed
Jan 1 00:00:06 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:06 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 00:00:06 kernel: rt3xxx-ehci rt3xxx-ehci: Ralink EHCI Host Controller
Jan 1 00:00:06 kernel: rt3xxx-ehci rt3xxx-ehci: new USB bus registered, assigned bus number 1
Jan 1 00:00:06 kernel: rt3xxx-ehci rt3xxx-ehci: irq 18, io mem 0x101c0000
Jan 1 00:00:06 kernel: rt3xxx-ehci rt3xxx-ehci: USB 2.0 started, EHCI 1.00, overcurrent ignored
Jan 1 00:00:06 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jan 1 00:00:06 kernel: usb usb1: Product: Ralink EHCI Host Controller
Jan 1 00:00:06 kernel: usb usb1: Manufacturer: Linux 3.4.76 ehci_hcd
Jan 1 00:00:06 kernel: usb usb1: SerialNumber: rt3xxx-ehci
Jan 1 00:00:06 kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:06 kernel: hub 1-0:1.0: 2 ports detected
Jan 1 00:00:06 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 1 00:00:06 kernel: rt3xxx-ohci rt3xxx-ohci: Ralink RT3xxx OHCI Controller
Jan 1 00:00:06 kernel: rt3xxx-ohci rt3xxx-ohci: new USB bus registered, assigned bus number 2
Jan 1 00:00:06 kernel: rt3xxx-ohci rt3xxx-ohci: irq 18, io mem 0x101c1000
Jan 1 00:00:06 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
Jan 1 00:00:06 kernel: usb usb2: Product: Ralink RT3xxx OHCI Controller
Jan 1 00:00:06 kernel: usb usb2: Manufacturer: Linux 3.4.76 ohci_hcd
Jan 1 00:00:06 kernel: usb usb2: SerialNumber: rt3xxx-ohci
Jan 1 00:00:06 kernel: hub 2-0:1.0: USB hub found
Jan 1 00:00:06 kernel: hub 2-0:1.0: 2 ports detected
Jan 1 00:00:06 kernel: rt2860v2_ap: module license 'Proprietary' taints kernel.
Jan 1 00:00:06 kernel: Disabling lock debugging due to kernel taint
Jan 1 00:00:06 kernel: APSoC AP Driver version: 2.7.1.6
Jan 1 00:00:06 kernel: RT309x AP Driver version: 2.7.1.5
Jan 1 00:00:06 kernel: rtl8367 - IGMP/MLD snooping: 1
Jan 1 00:00:06 kernel: raeth: HW VLAN TX offload enabled
Jan 1 00:00:06 kernel: raeth: HW IP/TCP/UDP checksum offload enabled
Jan 1 00:00:06 kernel: raeth: HW Scatter/Gather TX offload enabled
Jan 1 00:00:06 kernel: device eth2 entered promiscuous mode
Jan 1 00:00:10 kernel: =====================================================
Jan 1 00:00:11 kernel: Channel 36 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 40 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 44 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 48 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 149 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 153 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 157 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 161 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: Channel 165 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:11 kernel: =====================================================
Jan 1 00:00:11 kernel: Rule 1 CCA value : Min Dirtiness ==> Select Channel 36
Jan 1 00:00:11 kernel: Min Dirty = 0
Jan 1 00:00:11 kernel: ExChannel = 40 , 0
Jan 1 00:00:11 kernel: BW = 40
Jan 1 00:00:11 kernel: device ra0 entered promiscuous mode
Jan 1 00:00:11 kernel: device ra1 entered promiscuous mode
Jan 1 00:00:14 kernel: ch1 bssid=20:e5:2a:18:42:48
Jan 1 00:00:14 detect_link: WAN link restored!
Jan 1 00:00:14 kernel: ch1 bssid=ac:22:0b:d4:fb:30
Jan 1 00:00:14 kernel: ch1 bssid=b0:e7:54:1d:b4:31
Jan 1 00:00:14 kernel: ch1 bssid=26:4e:7f:94:c3:7c
Jan 1 00:00:14 kernel: ch1 bssid=b0:e7:54:d5:1d:b9
Jan 1 00:00:14 kernel: ch2 bssid=74:9d:dc:10:45:a1
Jan 1 00:00:14 kernel: ch3 bssid=00:24:01:39:9a:e3
Jan 1 00:00:14 kernel: ch4 bssid=b8:e6:25:77:e4:11
Jan 1 00:00:14 kernel: ch4 bssid=60:c3:97:07:d3:51
Jan 1 00:00:14 kernel: ch6 bssid=28:16:2e:0f:bc:91
Jan 1 00:00:14 kernel: ch6 bssid=b0:e7:54:f6:b0:f1
Jan 1 00:00:14 kernel: ch6 bssid=00:24:b2:0b:da:36
Jan 1 00:00:14 kernel: ch8 bssid=00:22:a4:82:c0:f1
Jan 1 00:00:14 kernel: ch8 bssid=ac:5d:10:93:7f:d1
Jan 1 00:00:14 kernel: ch9 bssid=d8:50:e6:d6:40:0c
Jan 1 00:00:14 kernel: ch9 bssid=3c:ea:4f:9c:af:11
Jan 1 00:00:14 kernel: ch10 bssid=3c:ea:4f:f0:55:49
Jan 1 00:00:14 kernel: ch11 bssid=64:0f:28:df:32:b9
Jan 1 00:00:14 kernel: ch11 bssid=00:1d:5a:78:a3:d1
an 1 00:00:14 kernel: =====================================================
Jan 1 00:00:14 kernel: Channel 1 : Dirty = 458, False CCA = 61, Busy Time = 12846, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 2 : Dirty = 378, False CCA = 76, Busy Time = 7350, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 3 : Dirty = 378, False CCA = 82, Busy Time = 3625, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 4 : Dirty = 444, False CCA = 27, Busy Time = 3902, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 5 : Dirty = 400, False CCA = 82, Busy Time = 3618, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 6 : Dirty = 434, False CCA = 69, Busy Time = 7939, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 7 : Dirty = 348, False CCA = 67, Busy Time = 4743, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 8 : Dirty = 404, False CCA = 44, Busy Time = 5069, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 9 : Dirty = 364, False CCA = 3, Busy Time = 2900, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 10 : Dirty = 314, False CCA = 38, Busy Time = 4007, Skip Channel = FALSE
Jan 1 00:00:14 kernel: Channel 11 : Dirty = 276, False CCA = 214, Busy Time = 7381, Skip Channel = FALSE
Jan 1 00:00:14 kernel: =====================================================
Jan 1 00:00:14 kernel: Rule 1 CCA value : Min Dirtiness ==> Select Channel 11
Jan 1 00:00:14 kernel: Min Dirty = 276
Jan 1 00:00:14 kernel: ExChannel = 7 , 0
Jan 1 00:00:14 kernel: BW = 40
Jan 1 00:00:14 kernel: device rai0 entered promiscuous mode
Jan 1 00:00:14 kernel: device rai1 entered promiscuous mode
Jan 1 00:00:14 kernel: br0: port 5(rai1) entered forwarding state
Jan 1 00:00:14 kernel: br0: port 4(rai0) entered forwarding state
Jan 1 00:00:14 kernel: br0: port 3(ra1) entered forwarding state
Jan 1 00:00:14 kernel: br0: port 2(ra0) entered forwarding state
Jan 1 00:00:14 kernel: br0: port 1(eth2) entered forwarding state
Jan 1 00:00:14 kernel: Ebtables v2.0 registered
Jan 1 00:00:14 dnsmasq[457]: started, version 2.68 cachesize 1000
Jan 1 00:00:14 dnsmasq[457]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-scripts TFTP no-conntrack no-ipset no-auth
Jan 1 00:00:14 dnsmasq-dhcp[457]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 7d
Jan 1 00:00:14 dnsmasq-dhcp[457]: DHCP, sockets bound exclusively to interface br0
Jan 1 00:00:14 dnsmasq[457]: read /etc/hosts - 3 addresses
Jan 1 00:00:14 dnsmasq[457]: read /etc/storage/dnsmasq/hosts - 0 addresses
Jan 1 00:00:14 kernel: usbcore: registered new interface driver usblp
Jan 1 00:00:15 kernel: Ralink HW NAT v2.50.7 Module Enabled, ASIC: RT3883, REV: 0105, FoE Size: 16384
Jan 1 00:00:15 RT-N56U: Hardware NAT/Routing: Enabled, IPoE/PPPoE offload [WAN]<->[LAN]
Jan 1 00:00:15 RT-N56U: Hardware NAT/Routing: IPv4 UDP flow offload - OFF
Jan 1 00:00:15 RT-N56U: Hardware NAT/Routing: IPv6 routes offload - OFF
Jan 1 00:00:15 kernel: eth3: ===> VirtualIF_open
Jan 1 00:00:15 DHCP WAN Client: starting on eth3 ...
Jan 1 00:00:15 miniupnpd[498]: version 1.8 started
Jan 1 00:00:15 miniupnpd[498]: HTTP listening on port 6490
Jan 1 00:00:15 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:15 kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:15 kernel: USB Mass Storage support registered.
Jan 1 00:00:15 RT-N56U: wan up (eth3)
Jan 1 00:00:15 dnsmasq[457]: read /etc/hosts - 3 addresses
Jan 1 00:00:15 dnsmasq[457]: read /etc/storage/dnsmasq/hosts - 0 addresses
Jan 1 00:00:15 dnsmasq[457]: using nameserver 75.75.75.75#53
Jan 1 00:00:15 dnsmasq[457]: using nameserver 75.75.76.76#53
Jan 1 00:00:15 DHCP WAN Client: bound (eth3), IP: 98.198.244.100, GW: 98.198.240.1, lease time: 312894
Jan 1 00:00:15 httpd[523]: Server listening port 80 (HTTP).
Jan 1 00:00:16 kernel: br0: port 5(rai1) entered forwarding state
Jan 1 00:00:16 kernel: br0: port 4(rai0) entered forwarding state
Jan 1 00:00:16 kernel: br0: port 3(ra1) entered forwarding state
Jan 1 00:00:16 kernel: br0: port 2(ra0) entered forwarding state
Jan 1 00:00:16 kernel: br0: port 1(eth2) entered forwarding state
Jan 1 00:00:26 NTP Scheduler: Synchronizing time to north-america.pool.ntp.org.
Mar 12 20:36:01 NTP Scheduler: System time changed.
Mar 13 19:17:28 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.1.128 ac:fd:ec:7a:6c:ef wrong address
Mar 13 19:17:30 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.1.128 ac:fd:ec:7a:6c:ef wrong address
Mar 13 20:35:51 NTP Scheduler: Synchronizing time to time.nist.gov.
Mar 14 06:51:36 dnsmasq-dhcp[457]: DHCPNAK(br0) 192.168.1.241 f8:27:93:3d:9a:2a wrong address
Mar 14 17:56:27 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.1.128 ac:fd:ec:7a:6c:ef wrong address
Mar 14 20:35:51 NTP Scheduler: Synchronizing time to north-america.pool.ntp.org.
Mar 15 04:00:14 detect_link: WAN link down detected!
Mar 15 04:00:20 detect_link: WAN link restored!
Mar 15 04:01:26 detect_link: WAN link down detected!
Mar 15 04:01:28 detect_link: WAN link restored!
Mar 15 04:02:22 detect_link: WAN link down detected!
Mar 15 04:02:26 detect_link: WAN link restored!
Mar 15 04:02:38 detect_link: WAN link down detected!
Mar 15 04:02:40 detect_link: WAN link restored!
Mar 15 04:03:28 detect_link: WAN link down detected!
Mar 15 04:03:34 detect_link: WAN link restored!
Mar 15 04:03:36 detect_link: WAN link down detected!
Mar 15 04:03:38 detect_link: WAN link restored!
Mar 15 04:03:40 detect_link: WAN link down detected!
Mar 15 04:03:42 detect_link: WAN link restored!
Mar 15 04:04:04 detect_link: WAN link down detected!
Mar 15 04:04:06 detect_link: WAN link restored!
Mar 15 04:04:46 detect_link: WAN link down detected!
Mar 15 04:04:54 detect_link: WAN link restored!
Mar 15 04:04:58 detect_link: Perform WAN DHCP renew...
Mar 15 04:05:02 detect_link: WAN link down detected!
Mar 15 04:05:06 detect_link: WAN link restored!
Mar 15 04:05:28 detect_link: WAN link down detected!
Mar 15 04:05:32 detect_link: WAN link restored!
Mar 15 04:05:34 detect_link: WAN link down detected!
Mar 15 04:05:36 detect_link: WAN link restored!
Mar 15 04:06:02 detect_link: WAN link down detected!
Mar 15 04:06:04 detect_link: WAN link restored!
Mar 15 04:06:26 detect_link: WAN link down detected!
Mar 15 04:06:28 detect_link: WAN link restored!
Mar 15 04:06:32 detect_link: WAN link down detected!
Mar 15 04:06:34 detect_link: WAN link restored!
Mar 15 04:06:48 detect_link: WAN link down detected!
Mar 15 04:06:50 detect_link: WAN link restored!
Mar 15 04:06:54 detect_link: WAN link down detected!
Mar 15 04:06:56 detect_link: WAN link restored!
Mar 15 04:06:58 detect_link: WAN link down detected!
Mar 15 04:07:00 detect_link: WAN link restored!
Mar 15 04:07:12 detect_link: WAN link down detected!
Mar 15 04:07:15 detect_link: WAN link restored!
Mar 15 04:07:19 detect_link: WAN link down detected!
Mar 15 04:07:23 detect_link: WAN link restored!
Mar 15 04:07:39 detect_link: WAN link down detected!
Mar 15 04:07:49 detect_link: WAN link restored!
Mar 15 04:07:53 detect_link: Perform WAN DHCP renew...
Mar 15 04:08:05 detect_link: WAN link down detected!
Mar 15 04:08:07 detect_link: WAN link restored!
Mar 15 04:08:43 detect_link: WAN link down detected!
Mar 15 04:08:45 detect_link: WAN link restored!
Mar 15 04:08:47 detect_link: WAN link down detected!
Mar 15 04:08:49 detect_link: WAN link restored!
Mar 15 04:09:13 detect_link: WAN link down detected!
Mar 15 04:09:23 detect_link: WAN link restored!
Mar 15 04:09:27 detect_link: Perform WAN DHCP renew...
Mar 15 04:09:49 detect_link: WAN link down detected!
Mar 15 04:09:51 detect_link: WAN link restored!
Mar 15 04:09:59 detect_link: WAN link down detected!
Mar 15 04:10:01 detect_link: WAN link restored!
Mar 15 04:10:15 detect_link: WAN link down detected!
Mar 15 04:10:17 detect_link: WAN link restored!
Mar 15 04:10:21 detect_link: WAN link down detected!
Mar 15 04:10:29 detect_link: WAN link restored!
Mar 15 04:10:31 detect_link: WAN link down detected!
Mar 15 04:10:33 detect_link: WAN link restored!
Mar 15 15:28:33 wan: perform manual connect
Mar 15 15:28:33 stop_wan(): raise DHCP release event
Mar 15 15:28:33 RT-N56U: wan down (eth3)
Mar 15 15:28:33 DHCP WAN Client: deconfig: lease is lost
Mar 15 15:28:34 kernel: eth3: ===> VirtualIF_close
Mar 15 15:28:34 RT-N56U: Hardware NAT/Routing: Enabled, IPoE/PPPoE offload [WAN]<->[LAN]
Mar 15 15:28:34 RT-N56U: Hardware NAT/Routing: IPv4 UDP flow offload - OFF
Mar 15 15:28:34 RT-N56U: Hardware NAT/Routing: IPv6 routes offload - OFF
Mar 15 15:28:34 kernel: eth3: ===> VirtualIF_open
Mar 15 15:28:34 DHCP WAN Client: starting on eth3 ...
Mar 15 15:28:38 RT-N56U: wan up (eth3)
Mar 15 15:28:38 dnsmasq[457]: read /etc/hosts - 3 addresses
Mar 15 15:28:38 dnsmasq[457]: read /etc/storage/dnsmasq/hosts - 0 addresses
Mar 15 15:28:38 dnsmasq[457]: using nameserver 75.75.75.75#53
Mar 15 15:28:38 dnsmasq[457]: using nameserver 75.75.76.76#53
Mar 15 15:28:38 DHCP WAN Client: bound (eth3), IP: 98.198.244.100, GW: 98.198.240.1, lease time: 248515
Mar 15 15:28:41 NTP Scheduler: Synchronizing time to time.nist.gov.
Mar 16 15:28:41 NTP Scheduler: Synchronizing time to north-america.pool.ntp.org.
Mar 17 15:28:41 NTP Scheduler: Synchronizing time to time.nist.gov.
Mar 17 17:47:53 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.11.200 ac:fd:ec:7a:6c:ef wrong address
Mar 18 07:11:54 dnsmasq-dhcp[457]: DHCPNAK(br0) 192.168.1.241 f8:27:93:3d:9a:2a wrong address
Mar 18 15:28:41 NTP Scheduler: Synchronizing time to north-america.pool.ntp.org.
Mar 18 19:28:09 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.11.200 ac:fd:ec:7a:6c:ef wrong address
Mar 18 20:30:57 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.11.71 74:e5:0b:01:cf:4e wrong address
Mar 19 15:28:41 NTP Scheduler: Synchronizing time to time.nist.gov.
Mar 19 18:10:00 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.11.200 ac:fd:ec:7a:6c:ef wrong address
Mar 20 06:27:27 dnsmasq-dhcp[457]: DHCPNAK(br0) 192.168.1.241 f8:27:93:3d:9a:2a wrong address
Mar 20 15:28:41 NTP Scheduler: Synchronizing time to north-america.pool.ntp.org.
Mar 21 15:28:42 NTP Scheduler: Synchronizing time to time.nist.gov.
Mar 21 20:02:29 dnsmasq-dhcp[457]: DHCPNAK(br0) 10.51.0.99 ac:fd:ec:7a:6c:ef wrong address
Mar 22 09:44:42 miniupnpd[498]: removed 11 unused rules
Mar 22 15:28:42 NTP Scheduler: Synchronizing time to north-america.pool.ntp.org.
Mar 23 15:28:42 NTP Scheduler: Synchronizing time to time.nist.gov.
Mar 23 20:24:59 dnsmasq-dhcp[457]: DHCPNAK(br0) 192.168.5.101 ac:fd:ec:7a:6c:ef wrong address
Mar 23 20:25:52 dnsmasq-dhcp[457]: DHCPNAK(br0) 192.168.5.205 f8:27:93:3d:9a:2a wrong address
