When the thing becomes broken (like mine) you don't have to do anything to get that infamous error message. After mine was "repaired" I found that it would work for about an hour before crapping out again with that message.
I talked to them multiple times and it was finally determined that it needed to be sent back AGAIN. At least this time they paid for the return shipping.
I returned it and waited another month for it to come back. I haven't yet tried to set it up this time but will soon.
Good thing I had an old 5 year old Linksys to use while it made the two trips back to them. It's less fancy than the Asus but it didn't crap out in less than a year either. When it comes time to replace the Asus I can't imagine I'd buy another one from them.
Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-N66U.
To access the settings of RT-N66U, reconnect to the wireless network and use the updated IP address and port number.
I recently setup OpenVPN using OEM ASUSWRT firmware. When attempting to access the router configuration (web GUI) from outside my LAN this is what is presented:
I'm connecting using the port number that I assigned for the router web interface. (using another port, including the standard 8080 simply does not return any page, as expected).
What has happened?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
