Cannot add any more port forwards, Asus RT-N56U, Padavan 3.0.3.8-081
kim_1138
Hi
Big problem, I can't add any more port forwards to my router.
The ones that are there all work perfectly, but all the ones I add just don't work. In the attached image you can see my forwards, yellow marked are the ones not working.
Even if I add a new pointing to one of the old that are working the new one wont work.
Have factory reset my router and the loaded my saved config. Haven't tried starting all over yet, its too tiresome.
https://www.dropbox.com/s/eod61az0tuhclpk/pf.PNG
Regards
Kim
Sweden
