Cannot mount USB drive - Seagate GoFlex 2TB
xtomiii
Hello
I have a seagate goflex 2TB drive, which is separated into 2 partitions.
First one is 512 GB ext2 for my TimeMachine backups.
Second is 1.5TB NTFS partition for my data.
When I plugged in the drive to my router I receive following ;(
Jan 1 00:00:11 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jan 1 00:00:11 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 1 00:00:11 kernel: scsi 1:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
Jan 1 00:00:11 kernel: sd 1:0:0:0: [sdb] Attached SCSI removable disk
Jan 1 00:00:11 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jan 1 00:00:11 RT-N66U: start httpd
Jan 1 00:00:11 notify_rc : stop_dnsmasq
Jan 1 00:00:11 notify_rc : start_dnsmasq
Jan 1 00:00:11 rc_service: start_dnsmasq is waitting stop_dnsmasq...
Jan 1 00:00:11 hotplug[506]: USB /dev/sda1(ntfs) failed to mount at the first try!
Jan 1 00:00:11 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jan 1 00:00:11 kernel: ufsd: unable to replay native journal on sda1
Jan 1 00:00:11 Samba Server: daemon is started
Jan 1 00:00:12 kernel: ufsd: use builtin utf8
Jan 1 00:00:12 kernel: ufsd: unable to replay native journal on sda1
Jan 1 00:00:12 hotplug[506]: USB /dev/sda1(ntfs) failed to mount at the first try!
Jan 1 00:00:12 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jan 1 00:00:13 kernel: ufsd: unable to replay native journal on sda1
Jan 1 00:00:13 hotplug[507]: USB /dev/sda2(unknown) failed to mount at the first try!
Jan 1 00:00:13 kernel: ufsd: use builtin utf8
In the administration the drive is detected correctly as a Segate drive, but it is not able to mount it. Any ideas? Highly appreciated!
Have a fine day.
Tomas
Hello, i'm having the same issue, except my HD is a Western Digital 2TB external.
I have the latest stock firmware 3.0.0.4.270
You might want to check if Merlin's latest (270.25b) firmware fixes your issue, as there are some USB HDD fixes included in version 270.24:
quote
- FIXED: Backported various kernel fixes from Oleg/WL500G, Tomato and Kernel.org to help improve HDD > 2 TB support (still not perfect, some USB enclosures are simply not Linux compatible)
unquote
Find full change log here:
http://www.lostrealm.ca/asuswrt-merlin/changelog.txt
