Can’t access ac56u after firmware upgrade
pmcd
I upgraded to the latest firmware 384.6 on my rt -ac56u. Works fine, except that I can no longer access it from my LAN. It has a static local address 192.168.2.32 . I used to https to it just fine. Now I can’t connect to the admin page unless I wirelessly connect to it and go via 10.0.1.1 . Is there an easy fix to this, or should I just restore the Asus firmware and reinstall Merlin?
After the flash, did you reset to defaults? If not, I would.
Oh and do not import any settings.
After I flashed it, it rebooted. At that point I had done nothing but I was unable to access it via my wired LAN. I am not sure what you mean by resetting to defaults. I didn’t import any settings. The old settings were just there.
