A
AlexandreG
Guest
Hi
I've been browsing your website for a while and I decided to register on the forums
So... Here is my situation... I have a small 1mbits dsl line going to my home. From there, I want to have 2 separate networks to isolate my computers from the other family computers.
To do so, there is 2 options... Expensive equipment with Vlans... Or what I've done in the past using multiple routers.
Now... I am comfortable with the idea of using multiple routers since it works, it's easy and it's cheap...
My problem is, I want a wired only router... Well, I can use a wireless and disabling the wi-fi..
I don't need gigabit ethernet or fancy things like vpn...
But I want it to be good... To have a good SPI, and to have good documentation.
I remember a DIR-615 that I had in the past (I think it is the same with most dlink routers) where you have the option of the NAT endpoint filtering... I REALLY liked this option. In fact, I don't really need it, but I want it to be port AND address restricted for everything... both UDP and TCP!
And I kinda liked the spi! It was clear! It was simply tracking session numbers and tcp flags for the connection.
This is what I find to be a good design.
The problem with this is that I really don't like d-link... I had some problems with them and there is sooo much problem with their latest firmwares that I just don't want to go this way!
The routers having those options are, from what I saw, UBICOM-based routers. The thing is, except for dlink, there is not a lot of those routers...
I saw 2 Trendnet, but they seem to be at their end of live (unable to order them in canada). And they all seem to be cheap clones of a unknown brand (to me) and I don't like this idea
But I am willing to pay more! So I saw thing like the Zyxel Zywall2Plus, that I find too complex for absolutely nothing...
I also looked at the Cisco RV042... Seems very good! In fact, I really like it! But there is absolutely no information about the nat filtering and the SPI algorithms. And the tech support is useless.. All they managed to say is that the SPI tracks more things (yeah... but what!!!) and about nat endpoint filtering, they never understood what I meant...
So here I am... not knowing what to buy...
Any ideas??
Thanks a lot
Alex
Any ideas??
Thanks a lot
Alex
