Change lan port to wan port
rbourne3
Sorry if this has been asked before. I tried searching, but it won't search for 3 letter words like lan and wan.
Looks like I was asking the wrong question. I want to know how I can access the setup on the node, so I can make a lan port the wan port.
I bought one of the T-mobile ac1900 routers and flashed to RT-AC68P. It worked fine until the wan port died. I bought a "real" RT-AC68P and it was working great. Both had a small area of my home with a weak signal. After reading about AiMesh, I flashed both to AiMesh firmware and set up the one with the bad wan port as the node. All working great.
I have a wired connection to the node available, but it needs to be connected to the dead wan port. Connecting it to the lan port does not work. Is it possible to change one of the lan ports to a wan port?
