Change mounting point for USB drive
gatorback
I believe my device automatically mounts a USB drive to:
/dev/sdb1 on /tmp/mnt/HOSTNAME type ext2 (rw,nodev,relatime,errors=continue,user_xattr)
I believe this was configured by an entware script. I'd like to change it /tmp/mnt/sda1
I tried to find fstab:
find . | grep fstab​
but it was not found. How is the mounting point assigned?
The name of the mount point (HOSTNAME) is derived from the volume label of the USB drive. If the drive has no volume label then sda1, sdb1, sdc1, etc. is used instead.
If you want to change the mount point, change the volume label.
