Change Priority of somba service
Stephen Becker
It looks like the somba service on my AC87U uses a LOT lof router CPU when my clients use it as a backup destination. For a decently powerful router, it is a surprisingly big problem, a single computer running robocopy is enough to increase internet latancy.
I would like to lower somba's priority so that it does not compete with routing services. I know I could write an init script to sleep 120 and then renice somba. Is there a better way to do it?
Also, is lowering the priority of somba the best idea? Or are there key services used for routing and QoS that I should instead increase the priority of?
You could renice samba, however Samba itself is only a portion of the CPU load - a good chunk of it comes from the USB driver itself, so I doubt renicing smbd will have a big impact.
One way to renice would be to create a postconf script that would launch a separate script (so the postconf script can immediately return), which would contain a sleep command (to give samba some time to launch), and then issue the renice command (use "pid" to find out the smbd process PID).
