Change settings on Aimesh node
monkey3ddd
I hope I'm not having a brain fart on this, but I try to access a node to change some settings and I'm redirected to the parent. How do I directly access the node to adjust settings? It "appears" that one node is on 5g mode, whilst the others are not
I hope I'm not having a brain fart on this, but I try to access a node to change some settings and I'm redirected to the parent. How do I directly access the node to adjust settings? It "appears" that one node is on 5g mode, whilst the others are notView attachment 11977
You can't access node directly (unless you ssh into it ) , all controlled from main node.
